? How to configure ICOM IC-200T
7SAC7
Jun 24, 2009
2
Hello and thanks for reading this message. Could anyone help me with
some info. I have been given an ICOM IC-U200T (UHF).
When I enter the known code (user password) only ‘reCH’ appears in the display. I assume that it is not configured. Therefore I need a how-to for manual programming. Some French papers is all I found with Google.
Would it be possible to get the rig onto 70 cms......????.
Any info would be Most helpful. Many thank's again and I look forward to
hearing from you.
Chris
Icom Service Manual Download Area...
... compiled by me ...
... courtesy of Marcucci, Italy...
ICOM Radio Service and Instruction Page
Standard Disclaimer:
I have no affiliation with whomever.
No legalities of material are considered.
No warranty as to accuracy of information is expressed or implied.
No warranty as to availability of materials mentioned therein is expressed or implied.
You break it... YOU broke it.
Thanks for the links.
I've downloaded these documents month ago, read them x times and still think they are crap.
Neither the user manual nor the service manual describes how to manualy configure the IC-U200T rig.
In another ICOM manual called "H16/U16 U2 V100/U400 V200/U200 V201 Programming/Cloning Maintenance Set" they write
"The IC-U2, ICV200, IC-U200 and IC-V201 habe no direct programming mode an cannot be used the MASTER transceiver."
I really do not belive this. Because I've read several reviews about this modell. Several OMs claimend to have programmed it by hand years ago before they brought a new one or a computer.
Maybe we can focus on this "reCH". What does it really mean?
Chris
