I have a tube amp that I am refurbing. This box was in a shed for many years, and there was corrosion everywhere. Not rust, just the white corrosion that metal parts get when they sit for a while. I disassembled it completely, and was able to clean everything except the chassis (some rust) and the plate/load variable caps. I bead blasted the chassis back to bare metal, and had it cad plated at a local shop. But the caps have me stumped. Only the vanes on the caps are corroded. I tried using my ultrasonic cleaner with some solvent, but it only removed about half of the corrosion. The plater said he could put them in his cleaning vat, but he thought the cleaner would damage the aluminum and the nylon bearings. I'm at a loss. Any suggestions anyone ???
- 399
- 399
