How well will a Ringo Ranger AR-2B perform w/o the radial kit?
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
Long story short, I was trying to erect my AR-2B today when it fell over, breaking 2 of the 3 radials. It also bent the top part. I did do an SWR check after the radials were removed and the top re bent back. The SWR's are 1.2:1 on 144.000 and 148.000 and a 1.7 SWR on 146.000. I did notice I am having trouble hitting a repeater about 62 miles away, but I can still sometimes get into it. How important are those radials?
Did you mean the ARX-2B? The AR-2B doesn't require radials. ;)
If it is the ARX the radials are important and required for proper tuning and performance. A quick search shows a part number for the radials of 082970. You might be able to get replacements through MFJ/Cushcraft. Another option would be to purchase some aluminum tubing and make your own. The measurements in the instruction manual show them being .25" X 20.5".
Yep ARX2B.....typo.
I think I might just re-thread the opposite ends of the radials unless there's something that says I can't.
What do the radials serve as? A counterpoise?
Actually, those radials serve more as a "line isolator" than counterpoise.
Exactly...and if the match is still good and you can hit a repeater 62 miles away then the antenna ia fine. If your worried about it then find some way ro replace the missing radials. I'd just leave it as is.
Thanks. I think I'm just going to cut some threads on the other end of the radio and put them in.
I tried looking up a line insulator, but didn't find what I was looking for.
A line isolator uncouples your signal from the feedline to prevent it from radiating. The MFJ-915 is an example of an rf isolator.
Be careful about cutting threads on ANY side of a radio!
LOL...I think he meant radial...not radio ;)
Yes I meant radial, not radio. Sorry for the typo.
Which was to no aval...the shop I work at didn't have the right tap and die set for me to cut new threads. Bummer.
And thanks for the MFJ link. That kind of helped me understand a little better.
