The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
dear hams ,
Can I use HRD 6.3 with Ft1200dx /w10 / scu-17
with voice as hrd wrote nor all rigs are compatible
(psk etc no problems)
I tried
(settings headphone -voice- ptt (f4) works but
no audio rx/tx
thank you for reading and advice
73 on3bm
You should be able to. Your radio needs the scu-17 for CAT control (radio control thru HRD) and audio for digital modes using DM780 within the HRD software.
Your audio in and out comes from your computers sound card with the audio information coming from the scu-17 which can be picked up by HRD.
You need to check your computers audio sound card and select the Yaesu scu-17 USB codec which should have some reference to it on your sound card dialog box.
If your not sure how to do this, Look for the speaker icon on your computer task bar and right click and select Playback devices and look for a reference to the scu-17 and set for default, then open properties and set the levels at least 50 percent for now. Do the same for Recording devices.
It may seem backwards but "Playback devices" on your sound card is for transmit audio and "Recording devices" is for received audio. This is important to remember since all references to audio in Amateur radio software settings follow this path.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
