HTX 10 meter radio
KJ4VRQ
Sep 9, 2013
86
23
18
Anybody got one for sale or know a place that I can find one? I'm watching a couple on eBay but was wondering if there is anywhere else.
I'm looking to buy one to use for my beacon with an ID keyer.
I did have one a few months back but it sold rather quickly. They don't make that radio anymore.
If you've noticed the ones on eBay usually fetch upwards of $100
My recommendation....hit up the local hamfest. I've seen the same radios sell there for anywhere from $40-$50.
Of course if you don't mind, the Magnum 257 looks like the HTX-10 and works 10M, only difference is the HTX-10 has a full VFO and the 257 does not, but the 257 has variable output...also the 257 can be easily modded to work on 11 meters.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
