CaptainKillowatt you are right. My insomnia has been acting up and my post's reflect this. Sometimes I do not sleep for days and sleeping pills do not always work either. So often after many hours lying in bed and being frustrated I get up and cruise the internet for 15-20 minutes than try again. Last night was the first time I slept in 3 days and I got about 1 hour of sleep sleep divided over 8 hours. The sleeping pills that my insurance cover which is only Ambien generic does not work that well for me most of the other stuff might as well be M&M candies because they do nothing.
I have tried sleep hygiene programs, meditation, giving up caffeine for months at a time, Melatonin, Valerian Root, Hops, Kava-Kava and the list goes on...
I hear ya. I too get very little sleep however I am not as bad as you appear to be. I do however suffer from Ice Pick headaches when I get tired completely out and that starts a bad cycle because they will keep me from sleeping which leads to exhaustion which leads to more ice pick headaches etc. Sometimes they are so severe I break out in goose bumps and can hardly remember what I was just talking about. Thank God they only last seconds or a minute or so but they certainly do live up to their name I tell you.
Also most LDMOS units people build for mobil use run at 48V not 100V+ like you would do for base station use. Since ever house in America has 110/220 available it would be silly not to take advantage of that fact and design accordingly on a car trying to get to 50V safely in a package that is not a monster that is reliable is a chore because unlike tubes that where high voltage but low amperage for the most part LDMOS have the same current requirements as a Bipolar but need a minimum of 48V to have significant gain and even better to have 100V or more depending on the part.
I have not seen LDMOS devices rated for 100 volts or more for common use however they may exist. Normal voltages are 28 volts and the almost universally available 50 volt devices. I see they now have a 1.5 Kw device rated at 50 volts.
http://ca.mouser.com/new/NXP-Semiconductors/nxp-mrf1k50h-transistor/
