id take the hygain, the sirio tornado uses thin wall weak tube.
Hey Bob, while I was recently modeling my New Vector 4000, I noticed that the tubing was a bit larger per tapered section that the HyGain SP500, except for the tip which was a lot smaller than I realized, plus it had a small top hat. I don't know about the tubing thickness issues, but the Vector looks to be heavier duty, except for this tip.
I checked my Sigma 4, starting at 1.50" vs. 1.25" SP500, 1.456" Vector. The Sigma tip is .50", SP500, .4375", Vector is .1875" which is very small considering it has a top hat.
It looks to me that all the newer antennas are weaker than we might expect, and if you're in a high wind areas like you, that could be a problem.
Heck, my old Starduster has a tip, .3125" x 27.5", that is pretty small.
Is the tip of the New Vector stainless steel?
