Well I never thought I'd say it but due to the changes from the original P500 it appears, at least locally, that the new P500 can be problematic in ways the orig usually wasn't, so personally I'll pass.
For true 5/8 performance you might look into the Sirio Tornado if you can use a lighter duty antenna where you live. One local guy replaced his Imax with a Tornado and saw a definite improvement in signal strength & noise mitigation, otherwise there's the Sirio Vector 4000 (NV4K) or the more expensive Zero5 5/8.
Not sure the Interceptor 10K is still in production, though the Shockwave 5/8 looks good and you should be able to extend it to .64 and reset the match to X=0 if you find having more medium TOA to be beneficial.
It's a bummer that several locals have had issues with the P500 insulators arcing out.
