I bought a used 8 element 2 meter beam. I was replacing the corroded parts with nice shiny stainless steel parts. I looked at the downloaded assembly instructions and see where there is a coax bathing balun. I see a part number for this also. Well I have tons of coax both 50 ohm and 75 ohm. I suspect this balun is made from 75 ohm coax but the instructions say nothing about the length of it. I have figured out where to connect it and would prefer to build it rather than buy it.
Does anyone know the length of this coax matching balun for the antenna?
It appears someone added the connector. Instructions point out where to connect coax pigtails. You can see the connector points for the coax center conductor and shield in this photo. Each side of the hairpin is where I see the center conductor was connected. The shield is still connected and cut. Now all I need is how long do I make this coax balun?
Thanks
Alan KJ7EFC
Thanks
Alan KJ7EFC
