I have tried and I cannot reteach myself the math. Hopefully, someone on here can. If you have two aluminum tubes. Each one is 38 inches long. If you connect the end of each one to the other and separate them at the other end by 120 degrees, what is the distance in inches between the ends of the two tubes?
