I HAVE ? ABOUT WITCH ANTENNA IS BETTER
cottentop
Nov 21, 2008
67
2
16
the panhandel of WV
OK GUYS AND GALS I GOT INTO CB AT 12 NOW I AM 43 YEARS OLD AND I HAVE USED ALMOAST EVERY TYPE OF ANTENNA SO OUT OF THESE ANTENNA'S HOW WOULD YOU RANK THEM
K-40
48 INCH FG WIP
4FT WILSON SILVER LOAD
BIG MOMMA
WILSON 1000
WILSON 5000 AND LAST LEAST
102 INCH FG WIP
I USED TO RUN 30 WATTS TO 250 WATTS
SO LET ME HAVE IT WICH IS BEST THANKS IN ADVANCE AND MAYBE THIS WILL HELP SOME OF THE OTHER NEW CBER'S AND UP DATE SOME OF US GUYS GITTING BACK INTO THE HOBBY
1) 102" STAINLESS steel whip
2) Monkey-Made Coil
3) Wilson 5000
4) Big Momma
5) Wilson 1000
6) K-40
The stainless whip is best, so long as you get it mounted favorably - hard to do.
Don't like the fiberglass ones; they break way too easy compared to the stainless.
The Wilson 5000 just has great specs, great reviews, and rabidly loyal customers. The Big Mamma base loads are tried and true, a favorite that isn't too easy to find any more it seems. I own a K-40, had it a long time too. Decent antenna that works great up to 200w - but not much beyond that. Just like the Wilson 1000 - pretty close. The stainless whip and the Wilson 5000 can handle gobs of power. So can the Monkey-Made coils; I don't know how well they work out for cars though. Mostly a truckers favorite antenna.
MM's and original Coilys are junk.
Heavy, welded junk.
Only coils to get are 10K's and 55's.
cottentop,
Lets see. You listed 6 antennas. I predict that if you count the number of responses, then multiply by 6, you will probably have the average number of 'which is best', with a slight tendency to lean to ward the 'Wilson's antennas. As with any statistical 'average', there will be a lot of variation in the reason for a particular response. Typically because the responder has never had one or two of those antennas to draw a conclusion about it, or may never even have heard the name before. So, very basically, you are conducting a popularity contest, who likes what 'best'. Nothing wrong with that, it's a fairly common market analysis. Unfortunately, that tells you very little about how a particular antenna performs, only what people have found to fit conveniently in their particular situation. Nothing wrong with that either, it can give you some very nice indications about practicality. Still tells you little about 'best' performance. So, you've found convenience, and practicality. Throw cost in there too, which falls under either convenience or practical, sort of. Also remember that you also have to sort by using the particular circumstances of each installation, which should also include 'looks' of the thing. Lots of variations in that one!
I've found that performance is almost always indirectly proportional to convenience and practicality, and has almost nothing to do with 'looks'. That translates into impractical for most circumstances, inconvenient for a number of reasons, and ugly. About the only constant in the whole thing is that ugly part, which is merely a matter of a 'eye of the beholder' thingy.
There's more.
It's a fact that different 'sizes' of antennas have different radiation patterns. Can't argue with that, it's just a fact. It's also a fact that those 'typical' radiation patterns result from the physical length of the thing. Not 'electrical' length, but physical length. Then you get to the point where some physical lengths just are not practical for the typical mobile. For instance, a 5/8 wave, 20 something foot antenna is going to have to lay waaay back to fit under a lot of stuff. Unfortunately, that 'laying back' also changes it's radiation pattern to something very 'non-standard' and can really negate the whole point of using that particular antenna, right? The closest you come to 'practical' with a mobile antenna at 27 Mhz is a 1/4 wave antenna. Oooo, tell me that's going to be convenient and not ugly, I dare you! :)
So you are sort of back to where you started. 'Best' ain't always 'best', only convenient, practical, and 'pretty' (sort of). And that will change according to the user and that user's situation. If it 'works' for you, then that's the 'best' for you.
Now that was a @#$$ of a lot of help wasn't it?
(All puns intended. Most of the above is fact. Almost none of the above is 'palatable' or common thought about antennas. Can't say I'm really thrilled with it either, but it doesn't change what is. Almost like politics, and ain't THAT a nasty thought?)
A lot of which is best is the application. That's sort of the same thing 'Doc said. I would run a 102" on my vehicle if I could, but I can't (for a few reasons), so I run a 4' fiberglass Firestik. It does the job I need it to do.
BTW, I agree about the MM junk comment...not that they don't radiate fine; the issue is that they're too heavy and not made very well. If I wanted to run a big, open coil antenna like that I would use a Predator 10k.
HI
Wel i liked doc's reply and a pal of mine is a trucker and just replaced a MM and he felt the same about the junk comment i have had good luck with the k 40 at 150 watts had to trim it some i am using a shakspear 3 ft trunk mout now it is ok for 3 to 5 miles and i agree a 102 is nice and shoots skip but man they hit every thing ill have to part with some green and try a wilson 5 k mag or trunk lip mount thanks also skip was running good here in wv today herd GA AL TX NY and my A99 is only 28 feet in the air pump it up LOL
    535A has left the room.
  • @ AmericanEagle575:
