Definitely considering a Rig Runner or similar power setup. However, the reliability of my present assigned truck is giving me pause regarding improving my radio system! VERY FRUSTRATING!
JD
The 4005
H (horizontal) might work well.
I’m willing to be wrong, but I couldn’t see the need to add fuses where the POS cable was already fused at BATT with a BUSSMAN termination fuse.
Thus my decision to use the POWERWERX
PD-8 block as it’s compact in comparison. The bigger 75A-size mains connectors were also attractive as I used 6-AWG in a 21’ [?] circuit in the Pete.
The standard 4005 Rigrunner (I have one) takes up some room, and having to run the lines causes it to need a good deal of free air space around it.
The “H” model makes it easier to package with radio gear, IMO.
Flat, as it were.
The aluminum
TAC-COMM TRC-1 Radio Carrier is where the Rigrunner really shines, IMO — meaning “type” of application — as one can envision putting all the gear into an easily dismounted arrangement. I’ve one of these and two of the larger TRC-2. One could have one on the truck dash with a fabric cover to match (hide in plain sight), and easily stow it away with APP making quick work of everything except coax where the 4005H is exterior-mounted.
I’ll be using the TRC-1 for the Linc in my pickup (give some protection). The KL-7505V will go in a TRC-2 under the rear seat (same reason). “Guarantee” the minimum airspace around each.
The main run power run is to the Amp under the backseat and would then be split at a Palomar Engineers
RFI-DC-30 to the Amp
and to the 4005 (power then sent to two separate locations for DSP or Radio).
Keep all fuses in one place. A sub-panel arrangement.
Was looking at 2 to 6-AWG and then 6-AWG to 10-ga BURNDY reducers earlier. Another $30 or so (that 12V filter uses 10-AWG wiring; which will
just sorta work into that 4005
and then forward to radio by 5-6’ more feet).
Point to this extra in your thread about my pickup radio rig
is that the accessorial costs add up faster than I expect.
A). Long run from BATT. Have to keep to .04 Volt Drop at TX (3%).
B). 12V Filter + Distribution panel have to have downsized wiring versus main run.
C). BURNDY
Reducers ain’t cheap. May have to do it in two (2) steps as well.
So, “smart” or not I opted to buy the PD-8 as I could run 6-AWG straight into it, and
anything sufficient out of it.
4005H + (2) Reducers = $100
PD- 8 (no reducers needed) = $45.
