The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
recently purchased a ICOM UT-106 i dont know where the ribbon goes..? i have instructions. i plugged it in without the ribbon and there is no DSP part on my menu display? is this filter not compatible with the NON-MKII and 2g versions?
You are correct. The UT-106 is not compatable with the old IC-706. It is with the MKII, IC-718 and some of their receivers. That info is available on the web.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
