Icom ID-51A Price and Availability
Ham Radio Nerd
Apr 14, 2002
9,267
1,871
283
Both HRO and Universal Radio are now taking orders for the new Icom ID-51A 2m/440 D-STAR HT, although it appears that they don't quite have them in stock at this time. The price is $649.
Here is a copy of the listed specs:
Compact Dual Bander
The 26.4mm slim body contains 5W output, VHF/UHF dual bands, a rich D-STAR and integrated GPS receiver feature set.
Independent AM/FM Receiver
FM, AM and shortwave broadcast stations can be listened to, while using the dualwatch function for monitoring ham bands. When a ham band signal is received, the broadcast station is automatically muted.
Automatic Position Reply Function (DV mode)
When receiving a call addressed to your call sign, this function automatically transmits your current position information. If the radio loses the GPS signal, the last position information with date and time information can be sent.
V/V, U/U, V/U Dualwatch
The ID-51A/E receives two bands simultaneously including in the same band*.
* When DV modes are set in main and sub bands, sub band audio will be muted.
Other Features
• TX voice memory (1 channel, 60 seconds) for repeated calls
• Voice synthesizer function announces frequency, mode and call sign
• Voice memory function records incoming and outgoing calls and can be used as a voice recorder
• 128×104 dots large full dot-matrix display (1.6 times larger than the ID-31A/E)
• CSV formatted communication log
• 10-step battery voltage indicator
• Integrated GPS receiver with GPS logging function
• IPX7 submersible (1 meter depth water for 30 minutes)
• microSD card slot for voice and log data storage and data cloning
• DR (D-STAR repeater) mode operation makes it easy to access D-STAR repeaters
• Repeater search function searches up to 20 nearby repeater sites
Specifications
Type: Amateur VHF/UHF transceiver
Frequency range: TX: 144-146 / 430-450 MHz
RX: 0.52-1.710 / 76-108 / 108-174 / 380-479 MHz
(5 / 6.25 / 8.33 / 9 / 10 / 12.5 / 15 / 20 / 25 / 30 / 50 / 100 / 125 / 200 KHz steps)
Mode: TX: FM/NFM and DV (GMSK: 4.8 kbps voice), Improved DR-mode
RX: AM/FM/NFM and DV (GMSK: 4.8 kbps voice), Improved DR-mode
RF Power output: Hi: 5/5 W
Mid: 2.5/2.5 W
Lo2: 1/1 W
Lo1: 500/500 mW
S-lo: 100/100 mW
Sensitivity: FM/NFM: 0.18 uV (12 dB SINAD)
DV: 0.28 uV (1% BER)
Selectivity: FM: 55 dB
NFM/DV: 50 dB
Voltage: 5.5-7.4 VDC (Alkaline or battery pack) or 10-16 VDC external
Current drain: RX: 200-450 mA
TX: Max 2.5 A
Impedance: 50 ohms, SMA
Dimensions (W*H*D): 58*105*26 mm
Weight: 255 gr (with BP-271 and antenna)
Manufactured: Japan, 2012-201x
Other: D-Star concept. Built-in GPS with logging. CTCSS and DTCS
1304 memories. Micro SD card slot. 128*104 dot-matrix display
Voice synthesizer. Voice memory. Voltage indicator. IPX7 waterproof
Twin RX
