Marconi said:
......it would seem to me to make an obvious difference. I cannot explain this, but for me it would seem to make a unexpected potential for error if one follows instructions precisely.
Nope, not a big difference at all.
Marconi said:
Maybe this is why some end up with one overall length and others are a bit longer or shorter. If it does have an effect then maybe this is why the doc's state that the overall length is not set in stone. Maybe the tuning, length, and tap point adjustments take care of the difference. Looks like very bad documentation to me.
There is nothing wrong with the documentation. Many factors will change the length and tuning of this antenna, this is why it is tuneable!
Marconi said:
Unlike MC, had I noticed that before I would have made mention of this fact many times in my discussions of this reported difficult antenna to install and tune.
This is a very simple antenna to build and tune. Installation is only as hard as the person makes it. I've never had any issues installing this antenna and whether the bracket goes up or down has little effect on the outcome.
Marconi said:
Master Chief maybe correct, that it makes no difference. But I would like someone to explain why, because seems to me all of those relationships down in that area are very precise as to location, measurement, and position.
The only issue is where RO2P mounts on the main radiator. PO8P, the bracket in question, has a pre-drilled hole in it and it mounts to the base assembly via a 10-24 screw. The difference between the bracket being mounted up or down is only about 1".
Marconi said:
The doc's even mention specific points (tips of screws) to measure for the 1" gap between the coil tips as important. The difference noted by Robalo could be as much as 1" difference or more, depending on how the part is installed. This would seem to me to cause and rather dramatic affect on the overall length as well as the placement of the tap point for the wire on the coil.
Once the PO8P bracket is installed and set up correctly, whether its up or down, you install the loop. Making sure you maintain the 1" gap, the RO2P "strap" will only have a difference of 1" where it meets the main radiator. Again, not a big deal.
IDEALLY, you would want the "strap" to feed the main radiator at the BOTTOM! But you can't do this as the bottom of the main element is buried in the insulator for support reasons. I bought a 12" piece of Teflon to elevate the main radiator out of the base tube but have yet to build it and test it.
Want to know what antenna correctly feeds the base of the main radiator? THE I-10K (and the Avanti Sigma 5/8). The Penetrator also feeds the main element at the base but surrounds the first 12" with the mounting bracket and ground plane. A flaw in my opinion.
Marconi said:
I guess both doc's that Robalo shows are from Maco. I would ask them which is correct and why the difference. For me it would seem to be an important note for Maco to address and to explain in their instructions on assembly. Maybe this is why Maco also comments about making overall length adjustment at the bottom section of the radiator instead of at the top segment.
It isn't important. Could it make a difference, maybe, but probably un-measurable. The ONLY reason Maco says to adjust the main radiator at the bottom is because it is more easily accessible during the tuning process. I would MUCH rather have the full 6" overlap at this joint and therefore take the extra effort to lower the antenna back down and adjust the top section.
What people need to understand is that the
"electrical length" of this "stepped" element is what is important. This length can be made up a number of ways. You could have a single piece of 14ga wire or a single piece of 1" aluminum tubing. The wire will be longer than the aluminum to make the same electrical length due to its smaller exposed cross section.
Most antenna element sections are cut in 6', 4' or 2' lengths as the raw material usually comes in 12' lengths and you don't want any waste. The wall thickness is ideally .058" in order to allow diameters in 1/8" OD increments able to telescope. Maco uses .047" material because it is cheaper. Avanti used .047" tubing only on the end elements that didn't have another stepped element inside. This kept costs down.
If I build an element with 6' of 1", 4' of 7/8", 4' of 3/4", 4' of 5/8, and 6' of 1/2", all with 6" of overlap, I'd have an element that is 264" long and it would have an electrical length of x. If I wanted to build another element of the same electrical length using only 4' material, it would have to be physically longer due to the reduced size of the exposed area.
What this means is that it does not matter what size material you use, or in the case of the V58, whether you adjust the top section or the bottom section, as long as you reach the desired
ELECTRICAL LENGTH of the radiator.
The reason I want the full 6" of overlap at the base of the element is for MECHANICAL reasons! 6" at the bottom is better than 4" at the bottom, mechanically.
I also want to point out the EXPOSED LENGTH of an element. What started as a 12' piece of aluminum is now a 1/4" shorter due to the cutting blade used to make 2 cuts. What this means is that the first two elements may be 48" when cut against a stop, but the remainder of the tubing will only be 47-3/4".
When I build an antenna, I don't "measure 6" and slide the ends into the larger tubing." If you do this, you could loose as much as 1/8" per element step. 6 elements = 3/4" off! On a sigma IV that's over 1".
If the tubing is 47-3/4" long, I call it a 48" and with 6" of overlap I would have 42" EXPOSED. The overlap would only be 5-3/4", but I'm OK with that.
Ham antennas and the I-10K talk about EXPOSED LENGTHS. The Maco doesn't, but I do when I build them.
