Does anyone know if solar panels "properly installed" on my roof will affect my imax 2000 antenna? Panels will be approximately 17 feet high and the bottom of the imax is 40 feet from the ground.. Thanks!
It is mounted on end of house at peak.. Not directly above but mast will be within a few feet of the solar frame..Where is the antenna in relation to panels? Mounted on roof above panels?
Question is, what materials are used in the panel.
Cells are silicon, covers are probably polycarb with aluminum frames?
If so might look a lot like a roof shingle to Rf.
Sent from my Nexus 7 using Tapatalk HD
