I just picked up a ground plane kit for my IMAX 2000 today that I bought used from a local operator. He is a new member to this forum. His name is Brian 264 and is also a member of The World Radio Club -"WR-264".
The kit is rather straightforward. Four fiberglass radials at/about 70 inches in length. They bolt to a 1/16 inch angle plate that also bolts to the IMAX mount. The angle of the radials appear to be about 35 degrees downward - that is a guesstimate. The whole thing couldn't weigh more than a pound or two - it's real light. The mount itself is flash chromed. Which is coming off in large sheets and the shards are razor sharp. I'll probably wire brush the daylights out of it to remove all loose chrome, and then spray it with some silver or aluminum paint - so it won't rust. But otherwise it is in decent shape.
I will install it on my IMAX and re-tune the SWR on the antenna before the Gizmotchy Beam review that is coming up soon...maybe by this weekend if everything goes as planned...the Gizmotchy beam should be here tomorrow - I'll post pics...
http://www.worldwidedx.com/general-...467-gizmotchy-beam-antenna-coming-review.html
Here is a drawing of the IMAX ground plane kit. The radials are much longer in real life as compared to this drawing.
