imax 2000 or spec 1600
Out of the two, Id go with the IMAX 2000.
Have you seen the materieals they use to build the Spectrum 1600? Horrible! The plastic coil housing has a tendancy to retain moisture also. It works and many locals seem to like them, but i've seen them fail and it not pretty.
f
I had my Spectrum 1600 up about 37' for many years. After about 2 years I lowered the antenna to tighten screws. An excellent performing antenna. Niether the Spectrum or the 2000 use top quality materials. I think the 1600 will outperform the Imax and is well worth the money (less than $100).
Just my opinion, LoneWolf TN
    535A has left the room.
