I just cant seem to get my Imax 2000 down at a good reading on my meter,it has 75 ft of br400 and 2 6ft jumpers and 1 3ft jumper in to driver and main 4 pill with the rings all the way at the bottom.I had the ground plain kit on and it made the swr jump up about three on the meter and the antenna was grounded at the plate of the base of the antenna and it was horrible.I had to take the ground plain kit off and ground the antenna at the bottom of the mast but before I took the ground wire off and I removed the Ground plain kit I have picked up a lot of static the comes and goes from 1db to 3db to 5db plus.I have been fighting swr issues with this whole setup since the ends were bad on br 400 when I recieved it from sparkys I replaced and I had 1.5 with all amps on with my old 100ft of rg 8u and then I put my br400 on and it went to 1.7 and swung backwards to 1.4 ish so I put imax up at 36ft and then I checked after I finished as the storm rolled in and swr's went in up to about 2.0 ish. I just dont know if I should take the antenna down and coax/jumpers and start all over again sinced I like to acheive the best swr with a 2x8 will be on order here real soon.I have never had such a hard time with setting swr and a little power.I dont know what the next step is now?:headbang:
