I had a forrest fire here about 3 weeks ago, and the fire burnt up about 300ft of hardline wire I was using going up the mountain, and this wire does lay on the ground...
And back there where I had my antenna the wire and where the coax was spliced into the wire it too was on the ground, oh and this coax is 24ft long and I was using LMR 400...
So, the fire burnt low on the ground, and it did burn the coax, the coax was black inside on the center wire it burnt a few inches that I saw, but too that is as far as I checked on it....my ground wire, the center wire also burnt inside it..
Ok, the mast pipe is 21ft tall, in which as you no this is where my antenna is on this mast pipe, and when the fire took places the antenna was 21ft off the ground...
Ok, what Id like to know, can the heat from the fire travel the length of the coax which was 24ft up the center wire to the base of the antenna which was 21ft, off the ground and damage the base of the Imax ?.....
Reason asking, since this has happened, I had to move my antenna down the mountain about 200ft from the top, and I had to replace the wire I had laying on the ground, and I replaced the coax with 24ft of RG 213 coax, and replaced the ground wire with 10ga house wire I had left over from a job, and my swr is still a 3 and on up into the red....I have the antenna hooked up now and have been listening to the locals talk on it....but havent talked on the radio do to the swr been like it is...
So, hoping you guys can give me some info where to go from here....
I was going to go up there today, and take the antenna down, and check the swr in just the antenna, just to see if the antenna is in deed ok, just from looking at it, it looks to be ok...but after the fire, I didnt check the swr or anything in the antenna, since the rings, and the antenna all looks ok...
But I dont no if the heat from the fire could travel up inside the coax and do anything to the insides of the Imax....could this happen and not show any damage to the antenna from the outside ?.....
Really dont no where to go from here, so I sure could use some good advise..
