Inspect Your New Amps
Recon
NY 881
Jul 28, 2019
1,083
1,263
173
Up-State NY
New amp arrived and I was curious as to what type / name of the pills were installed. I removed the cover and found two defects as per the attached photos. Both cables are not secured to prevent them from being pulled-on the soldered connections. Any idea what the floating thick washer-looking object is?
That round donut looking thing your pointing at in pic one is not there to secure the cable. It's a magnetic ferrite choke. I think X-Force amplifiers used to come that way.
Reactions: Cable Guy
Yes, I realize it is not to secure the cable, I just did not know what it was. For crying-out-loud, it can't cost that much to use and install a watertight strain-relief grommet to ensure the cables don't get pulled-out.
I've seen some of the amp builders use string and do a fancy little knot to keep the ferrite in place.
A strain relief on the power cables should have been a default. Nylon cable glands work really nice for those.
I would definitely recommend installing a strain relief. Or at least something to protect the wire's insulation from the sharp edges of the cabinet.
There are plastic pass-through grommets installed to prevent chaffing. A five-cent Zip-Tie would be better than nothing to prevent the cables from being pulled-out.
Does this amplifier have a name on it?
Might be worth knowing who to stay away from.
I'm not disclosing the manufacturer of the amp, because I was informed that this is just about the "norm" with many amp and power supply builders. I recommend retaining the photo and if and when you or anyone orders a new amp or power supply, forward the photo to the builder and ask if that is how the power cables will pass through the cabinet.
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
  • @ kingmudduck:
