it's very possible Small ,there's a little bit more to it then just the final change but if you were to change the driver as well to a 2314 and jump the anti-spiking diode (the big one that runs along side the audio transformer in the radio) it's the big one ,you can possibley see about a 7 to 8 watt DK with a 30 to 35 watt pep swing,but to see the 40 to 50 watt pep you would have to change a few more parts but even still,7 to 35 ain't bad and if you were to do a cap/resistor mod you could see 1.5 to 2 watt DK swing'in that same 30 to 35 watts pep ,now that ain't bad for a regular ole cb radio don't cha know ...damned near turns that puppy into export quality Godd Luck too you.
