The Vero VR-DB2R is a new Chinese 2m/440 or 2m/220 5 watt HT that will be available soon. This radio is interesting because it is both full duplex and IPX7/waterproof.
Here is the information that is available so far:
- Frequency range:
- 136-174 & 300-350 MHz (TX/RX)
- 136-174 & 350-390 MHz (TX/RX)
- 136-174 & 400-470 MHz (TX/RX)
- 136-174 & 450-520 MHz (TX/RX)
- 136-174 & 245-246 MHz (TX/RX)
- 144-146 & 430-440 MHz (TX/RX)
- High/Low Power Switchable
- 25KHz/12.5KHz Switchable
- Auto Contact Function - This function is useful for environments which need close communications, such as climbing, exploration and rescuing. The radio will beep when the users are out of communication range and this function is ON
- Auto Output Power When in Duplex Status - When the VR-DB2R is in duplex status, it can automatically adjust the output power based on the distance between two radios.
- Channel step - 5K/6.25K/10K/12.5K/25K
- PC Programming
- Dual Display, Dual Standby
- Whisper Function - This function can be enabled in quiet environments, allowing you to speak quietly into the radio and still be heard clearly.
- CTCSS / DCS
- FM radio :88-108 MHz
- Transmission Time Out
