The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
I have noticed if I am scanning the right side with Air, Local PD, FD, EMR and so on if the Key tab is on the LEFT where Ham VHF UHF is used to Transmit, The right side suffers from Intermod. Will this solve the problem: PAR VHFDN152 Filter ?
Read the advertisement. It says it will 'notch' out the 150 Mhz range, so, you won't be hearing it anymore. IMD would be a factor is you were transmitting on the 150 Mhz range, but not if you are just listening.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
