I have a Executive that isn't showing any high voltage at the Filter Caps 100/100 500V , I disconnected the leads and the Caps test good. Looking at the schematic were should I start to look for my High Voltages?
Some voltages I tested.
Filter Caps both 0.0 Vdc
Converter Circuit:
Pin 4 13 Vac
Pin 5 7 Vac
Pin 6 O V
I.F. Unit
Pin 16 0 V
Pin 21 13 Vac
Pin 22 7 Vac
Audio Unit
Pin 33 & 35 0 V
Pin 36 12Vac
Pin 37 7Vac
http://www.cbtricks.com/radios/international_crystal/ctz_100c/graphics/ctz_100c_sch.pdf
Converter Circuit:
Pin 4 13 Vac
Pin 5 7 Vac
Pin 6 O V
I.F. Unit
Pin 16 0 V
Pin 21 13 Vac
Pin 22 7 Vac
Audio Unit
Pin 33 & 35 0 V
Pin 36 12Vac
Pin 37 7Vac
