My previous setup: A homemade horizontal dipole using two 4' Firestiks atop a 15' mast.
I am now using a similar antenna in an Inverted V orientation in my attic.
The advantages:
1. The attic allowed me to gain a few feet in height over my 15' mast.
2. The Inverted V is more omni-directional than the horizontal dipole I was using.
3. With the coax hanging straight down from the feedpoint, the impedance should be closer to 50 ohms than with the horizontal.
4. In the attic it's protected from weather.
5. It's STEALTHY!
Here's the build:
I began with a Simpson Strong Tie #LSTA12 from Home Depot. This version is very thin and lightweight.
And it bends easily!
For increased rigidity I added a small "L" bracket.
This strong tie comes with a couple of 1/2" diameter holes which I used for the stud mounts. Using nylon washers, I isolated both antennas from the bracket. I then snugged a small zip tie around the coax and through an existing hose for strain relief.
To suspend the antenna from the rafters, I used a piece of coat hanger and two other existing holes.
The finished product!
In place!
All that's left is to connect my 23 channel Cobra 85 Dynascan and check the SWR.
CH 12: A tad over 1.1
Channels 1 and 23 were both 1.2
The Firestiks I used have adjustable tips on top but no tuning was necessary!
The skip was rolling in from everywhere: Boston, Mobile, Honolulu and Barbados! After several minutes of trying without success, I finally connected with a fellow in Rhode Island. Not bad for a homemade antenna, a 40-year-old radio with a stock mic and 3.5 watts!
Is this a great hobby or what?
My thanks to John Reisenauer and Scott Wolfington whose articles started me down the path of using mobile antennas for my base station.
http://www.hamuniverse.com/cbstrongtie.html
The advantages:
5. It's STEALTHY!
Here's the build:
In place!
