Hello FDTrucker:
You may have to install a Balun inbetween the coax and the dipole elements.
The Dipole antenna has one of its haves or elements connected to the coax shield, and the other half to the center wire in the coax. The center wire can not radiate as its inside the coax shield. But the coax shield will try to have currents running back down the coax that will effect the antennas performance and SWR.
So a Balun is installed between the coax and the dipole elements to do two things. 1- Choke off any sucificant currents going back down the coax shield, and 2- force equal current onto each of the dipole elements. Especially if you use a lot power.
Winding the Coax in a coil to act like a Choke or Balun does not work for me, as I tried this on my beam antennas. So I used a Toroid Core type Balun, and that worked much better. Here are a few sites that should help.
www.arising.com.au/people...MBalun.htm
www.davisrf.com/ham1/baluns.htm
www.amidoncorp.com/aai_cost_baluns.htm
Please let us know how it works out for you.
Jay in the Mojave
</p>
Jay in the Mojave
</p>
