This seems to have an antenna that measures field strength? Is this when one would need a dummy load?Awesome!! There would be nothing wrong with getting one of the lesser expensive ones and connecting it in. For a
Awesome!! Connecting it to your setup is pretty straight forward. You will need a sampler so the "full power" of the radio is not sent to the freq counter. Try searching on *bay for RF Sampler Modulation Monitor as an example of what could be used. If you use an amp make sure that the sampler is BEFORE the amp!!!
Let us know how it works out.
