Asked some people via PM but using it with my phone is well I screwed it up.
One person responded and then apparently I deleted their answer when responding with more specifics below and the other either didn't see, or couldn't be bothered with me, which I also understand completely but I still don't want to waste 300 bucks if no improvement will be gained by a new tube. But if my numbers are soft it would "behoove" me to replace and have a "spare" on hand. Tube is older Eimac I believe based on design, I saw no lettering.
Test equipment
Yaesu FT 710
AL80A 1x 3-500z
MFJ 826B on peak setting
Dosy TC 4001 P on pep setting
MACO VQUAD beam as Max2000 omni gives false power readings I believe possibly due to higher reflect, IDK.
(swr is similar to beam but reflected power w amp shows 45ish watts reflect vs 4.5 watts on beam yet Max2000 swr isn't high and beam power output shows quite a bit lower and these lower potentially more accurate figures are what I've posted)
Results
Yaesu SSB NO AMP / 116 MFJ / 80 dosy
Yaesu SSB AMP / 720 MFJ / 575 dosy
Yaesu AM DK / 35 MFJ / 30 dosy
Yaesu AM Modulation / 52 MFJ / 30 dosy
Yaseu AM DK AMP / 350 MFJ / 300 dosy
Yeasu AM MOD AMP / 475 MFJ / 325 dosy
I also just for test purposes did a one time basis turned down the yaesu and put my 2x Toshiba cobra amp inline @200 ssb Into AL80A hit just over 1k pep. This amp is not inline for use and was just a test. Other individuals results w a 3-500z achieved much higher output with much lower input so I am a little concerned.
Tube experts please help me out.
Thanks!
Test equipment
Yaesu FT 710
AL80A 1x 3-500z
Results
Thanks!
