Is the case needed?
T23
645
12
I was wondering, is it needed to have the metal box or case on a transmitter, a tube transmitter to be exact? I see this alot in photos of older transmitters with only a chassis and front panel (ham wise).
My question is arent these needed to sheild from rf exposer?
T23
The case definitely provides shielding from RF not only to the operator but it keeps RFI down as RF is not radiating from the unit but rather is fed to the antenna as it should be. Most likely a lot of the older gear you see with just a front panel and chassis was meant to be installed in a large equipment rack which provided the shielding.
