MC does your original Sigma IV have 3 or 4 radials in the cone?
Plus you state:
Building a bulletproof Sigma IV is easy! Finding a better way to feed it is another issue.
I'm a believer that a gamma rod exhibits more loss in the feed point than possibly a beta match. How to pull it off is another issue.
What is you’re bases for this statement? Have you anything besides the words for you and Jay's on that claim about the losses relative to the use of gammas? I do not know the answer, but I hear you both state that repeatedly. I know that you have a different feeder idea for the I-10K and that is a fine feeder no doubt. You both claim to have done field strength test and I know just how difficult that is to accomplish without some very elaborate testing equipment. I would like to hear just how you did that testing and what you used to do that work of FS testing.
I read the piece by Cebik, where he discusses the issue of feeder losses, but I could not find where he definitively stated one way or the other which is best. If you refer to this piece as your evidence then put me on the exact part where Cebik says that? If it says it at all, I will bet he also claims that the difference is so small a difference as to make no difference.
Have you tried a trombone feeder inside of a mockup sigma design to see if you can find a better way to feed the Sigma design directly? The only problem I have ever heard gamma user’s claim about their feeding method has to do with the construction using “Plumbers Delight,” and arguing that using an insulated driven element with a hairpin, tapped coil, or the trombone device is the inherent weakness with the physical use of the insulator and the material it is made off. Don’t you have about the same problem bring a radiator element to ground via a capacitor (insulator) as does the gamma transferring RF thru a small air gap or thru a thin dielectric medium.
Personally, I believe you and Jay both have a very high regard for the Sigma IV design and that you probably started out trying to redesign with Jay’s new idea as the bases to start with. Problem with that was how to make it different and I believe you ran into problems figuring out how you could do that.
I have no quarrel with the I-10K. It is a find device and is very well engineered, very physically sturdy, and is something for you both to be proud of, but it is not a Sigma IV. Personally, I have never seen another antenna besides the Sigma IV lay down such a big signal in the local area of the antenna. But then again, I don't believe that signal is all that is important in an antenna without consideration of many other things, so the point about signal is mute with me. I have talked to folks on my radio that showed me absoutely no signal at all, and to tell the truth I could tell little difference when through with the conversation how the stations compared, one not signal and one showing me a signal of 30 over S9, cause I heard and spoke to both. Now if I thought they were both neighbors I might wonder a bit.
