I have it mounted in a pine tree vertical, yes its prob not ideal to be so close to the main part of tree, but i have limited options right now, mainly need to be out of sight. I am in the country and own the property, but wife doesnt want to see much in the way of antennas. My set up is complety invisable unless your under the tree lookimg for the wires. The bottom of the dipole is about4-5 ft off the ground. Is there any use in adding radials on the ground and what length should they be, the antenna halves are 103" each. Also the ground under antenna is flat one one side and runs down hill on the other. Would it be benificial to put any radials down the hill a bit? Or right under? Any advice appreciated
