Is it accurate? Given that the size/diameter of the conductor used, and where the thing will be mounted always has 'some' affect on accuracy, it's accurate enough. There will always be some 'adjusting' of the feed point taps, that's normal.
One suggestion for VHF/UHF 'J'-poles is to add a sort of 'tuning adjustment' to the top of the long element. Solder a nut and bolt to the end-cap so that you can adjust the element's length. Not all that necessary, but it doesn't hurt. that tuning adjustment nut/bolt is naturally longer for the lower frequencies, maybe not as practical for 27 Mhz, and definitely a looong bolt for the lower bands. Taking a sort of 'step back' and looking at it objectively, nothing says you couldn't use a tall tower and a 'tuning stub' to make a 'J'-pole for several bands in one structure... sort of like a '18HT', huh?
(18-HT = a 'Hi-Tower', now owned by MFJ. Gotta be the best "all band" HF vertical antenna around if done correctly.)
(That 'choke' isn't a bad idea for any/all antennas.)
