JASON MODE
doctor
Supporting Member
I Support WorldwideDX.com!
Aug 1, 2006
1,036
80
58
82
indiana
I checked out the wspr, worked the first time, but no condx on 30 today from here.
I see ops are using a mode called JASON, anyone use it..band...or info appreciated.
DOCTOR/795
"Jason" is a new one for me. I haven't heard of that and am not finding much info. Got any links? How did you find out about this mode through WSPR?
go here: K3PGP - Experimenters Corner - Software and look under "digital moodes" , you can download the software.
there actually are 2 (two) different programs "Jason" amd "Jason Turbo"
they seem to be used for LOW FREQuency only.
the S/N ratio seems to far exceed WSPR:D:D (if that is possible)
i just d/l it yesterday and am running it now for the first time.
5 watts,...... working UA3's & DL2's on 10 meters 28.126MHz.:tt2:
JASON
Where are they..ops..running it, or what frequencies.
I did download it, but it isnt xmiting will investigate more on it.
Also will check the turbo out, for JASON, never heard of the turbo part.
DOCTOR/795
JASON
HOOKEDON6
What is your secret operation to get JASON going, I downloaded it, seems to receive but no xmit, at all.
DOCTOR/795
HOOKEDON6
DOCTOR/795
we have worked on sstv (mpn73-n mode) 30 meters before. :biggrin:
did you configure it to an available comm port?
also on 10 meters:28.126MHz is active
JASON
Will check it out in a while on a com port...
I was just on sstv on 30 a few on but condx are not the best today
DOCTOR/795
JASON
Ok I got it to xmit...does it have a steady tone while xmiting, it must be doing something i put a test in the bottom and hit enter, and after a short time period it disappeared it must have gone out..hopefully, what frequency on 30 meters does one use...
I found out dont select a com port and thats is how I got it working..if the tone is what you hear when the top on air display flashed.
DOCTOR/795
