I found a lot of little errors in my old model with a physical trombone matcher included.
The matcher does work to make a fair match, but this antenna is very sensitive to tune in the real world and with my model.
Bob, I started with the specs noted in the manual on the first page or two with a range chart for dimensions.
Later I used the math calculators that Jay gave us that allows me to be more specific with the frequency. I modeled at 27.205 MHz. The math is close for V7 the tip length, but the the range chart is not nearly as close and it takes a lot of trial and error to get it right. The match dimension for H3 is very close using the math and the range chart is pretty close too. That said the radials don't seem to change that much. I used the math for the radiator and the 257.328" inches I got is what I used. The math is the only way to go. I did not use the radials or the radiator to tune...if was all tweaking the trombone tuner.
I also noticed that every dimension for T1 and T2 in the range chart, with the exception of the range 27 to 28 MHz, shows T1 longer and T2 shorter. All the other ranges are the opposite for the 27 to 28 range. When I tuned my real antenna this is the range I used, 27 to 28 MHz I never did think I had it tuned right and I think this range could be backward in the manual. I even tried it today and no-way-no.
The first model I did, sometime back, was using the range chart for 27.205 and it was no-way-no. I used that model to start with Eznec again today. I was trying to get the model to perform and show a perfect AGT result = 1.
I did not use taper, so that could make a difference...if I did not use a good average radiator diameter over the full length...which was just a guess. I did not try and test the 0.875" average diameter for the radiator I used here and the 0.50" diameter for the radials was a guess too. That said, my model shows resonance at 27.300 MHz with an SWR = 1.19:1 and that is another good sign.
I was surprised the model looks so good. My earlier models, with all the errors, I posted here on the forum several years ago...looked even better...maybe too good.
I posted the dimensions in my Eznec antenna notes included in the PDF file.
Seeing as I just posted some comparison models at 705" inches to the tips for various models in my thread "Bob's Avanti AstroPlane model," I set this model at 705" inches to the tip as well.
Bob, if this model is even close...don't sell your I-10K.
