jc penny 6248 variable alignments?
i'll see if i can find the rest
hey thanks i got it working but this helps with the clairifier mod and alighnment which is no prob with this info this radio is basicly new never seen a 6248 in this good of shape
Just lock in the clarifier if you really want to, but don't add a "super diode" or a choke in series with the varactor. It will be impossible to fine tune that way. Usually all clarifiers can be locked in by disabling the TX voltage to the fixed TX frequency adjustment, and then removing the RX source from the claifier which is switched on for RX only and moving it to a stable constant voltage source.
