I need some diagnostic help with my CB antenna. I drive a soft top Wrangler and currently use a commercially available mount that bolts to the body tub behind the driver side tail light. I have a 4' Firestick II that gives me a good SWR reading, but due to the height of my vehicle, the mounting location and my garage door, I am about 6" too tall and even with a HD spring it still eats up the plastic isolation bushing in a few weeks. Due to the soft top, getting the top of the antenna up and over the roofline generally is not too big of a deal, and a 3' Firestick would fit better in the garage. Trouble is, my 3' 'Stick II will not tune below 2.5 SWR. Just experimenting with other antennas I have lying around, my 5' Firestick II and 4' Firestick (not tunable) also give me terrible SWR. A simple mag mount from WalMart stuck on the front cowl works great...go figure.
I'm missing something here just not sure what?
Plan B would probably be to swap to a steel whip antenna (my 2m antenna doesn't mind a regular bend in and out of the garage), but since we are often in tight quarters off road Firesticks or equivalent are viewed as safer since they are flailing around less than a whip would.
