So as the title says i just picked up a old Texas Star dx667v and i have a nice new 150amp variable power supply. My question is what voltage should i run it at? If it matters it uses non red dot toshiba's and it seems to run without any problems. It does have a 120mm fan kit installed under it. As of now it has the original wires powering it but soon i would like to do a replacement of those power wires and also replace the stock fuse setup as i understand that a area of concern. So i can set voltage from 12.30 volts up thru 15.90. I am not looking to squeeze every last watt out of it and plan to pair it to a non "tweaked" Cobra 2000 and to a non "tweaked" Cobra 148.
Please advise as i would like this to last a long time.
Thank you all.
Thank you all.
