Have 97' RG8x
Is this bad or what it is dark so cannot do much at all? I appreciate any suggestions and explanations on dealing with it ect. Getting back into all this just curious and all on things and why they happen as well.
Thanks
97' is ok if the feed line through put for your 100' foot line is close to 93% of input or better.
I always try and check my coax at the radio end of the feed line too, and see if adding a couple of extra feet makes a notable change in my SWR results too...if I ever get concerned. Then, if it does make a difference you can see the results on your inline meter. If this happens, then your problem may be as others have described here already...CMC. If such a condition is not bad however...it is not the end of the world.
Before I install an antenna high up, I try and always check the antenna match at the feed point when possible, else get as close as possible with a shorter run of coax. Even though you have to test close to the Earth in this case, that is better than no check at all. To be clear I'm not suggesting the match near the ground will be the same as it can be when raised up high.
HM, if you don't understand this, or how to check this...let me know.
LOL, I know, i talked to several guys on open coax laying on top of the house once just for grins.
For his use i think it will be fine.....someone once said that we are lucky that our antennas don't necessarily have to be perfect to work.
I agree Jeff, we all may have experienced similar events. I don't see anything in Heavy Metal's report above that indicates his situation might cause damage either. Maybe he is just putting too much importance on his SWR. We all have probably been down that road.
Jeff, if you check out my signature below, you will read that I make a similar claim as you note.
My old radio mentor use to make similar remarks to me all the time, and for me, I've never forgotten such implications in those important remarks.
You also gave HM a good description on how and what to check.
BTW Jeff, aside from a really bad physically damaged feed line...have you ever worked a feed line that had very high losses due to deterioration from "old" water in the feed line? You might be surprised at what you could notice with such a feed line.
