Just a quick post to see what others have to say. To start off, I have pretty much always used a Wilson 1000 or 5000. A couple antenna gurus that I met back a few years ago did antenna modeling in several spects of the Wilson 1000 and 5000 vs. a lot of the other CB antennas that were out on the market at the time such as the big coil type antennas like the Predator 10k, monkey made, and a few others. It turned out for MANY reasons the Wilsons came back almost every time as better performers for most situations. I say *most* situations because I do realize there is NO perfect antenna for every situation.
With that said, recently, we came across a batch of K40 antennas and their respective magnet mounts N.O.S. (new old stock) and subsequently 4 vehicles that needed installs.
I'll skip a lot of the non-important details, but basically the mobile setups were running 2970dx n2 radios, and using the K40 antennas two magnetic mount, and two permanent mount.
Once getting them all set up on the MFJ 259B antenna analyzer, it was time to get the installs all neatly done and get everything wrapped up.
Over the next few days, we would hear the users of the antennas in our group on the air, and I must say, they work great. It seems the K40 has been picked on, and under-rated a lot. The results on paper (analyzer) and also real world results were a LOT better than expected.
I would recommend a K40 to anyone that is not running a huge amount of power. We will see how they physically hold up over time in the sun, heat, wet, cold, etc but so far so good!
