I got my K40 today. It claims to be a universal mount, either trunk lip or thru the roof. Instuctions for roof mounting simply tells you to mount the plastic base to top of roof and tighten the set screw from the inside. There is no gasket (foam donut) included, nor is it mentioned anywhere in the instructions that you need one.
https://dl.dropbox.com/u/39278999/NewDoc.pdf
There is a rubber gasket for trunk lip mounting, but it's insufficient for roof mounting.
Called K40 tech support, talked to two different guys. I ain't kidding. neither one had any technical knowledge at all.
Copper sells the donut for .99 cents, but wants around $12.00 shipping. Solid Signal, which is where I bought the antenna wants close to $15.00 total for a 1/10 of a penny foam donut.
The damn donut should come with the antenna!
K40 has obviously went to shit.
The moral of my story...Stick with Wilson Roof or some other proven design.
