my advice is to not turn this amplifier on or even plug it in until you refurb it with that kit.
after that, a dim bulb tester is a good idea when turning on tube equipment of dubious history or work.
be sure to note the polarity of all the electrolytic caps as they are before you replace them as you really don't want to get that wrong, and it may or may not be noted on the PC board.
be sure to pull all the tubes out before plugging it in for the first time, and if it has been plugged in recently, then you need to read about safety and tube equipment.
(i guess do that anyway lol)
take a look at that coil sitting horizontally right between those two variable capacitors.
notice how it looks like it's taken a beating?
someone has been trying to "peak" the output of that amp or tune it for a different frequency range and you should make sure no unintentional shorts exist between turns or to the chassis of the amp etc.
there is a ton of great literature out there about how to safely work on tube equipment and it is unwise to attempt it without knowing about all the ways it can kill you.
