Kenrich Eagle VIII
Also, should I be concerned with this ? Not sure why they didn't add the resistor here it looks like they put a drilled out set screw here instead, anyone know anything about that ?
It looks like a ferrite core out of a tuning can. Someone thought it would be equal to the resistor/wire wrap? I would be tempted to make it like the others.
Reactions: Danzik
It's kinda hard to explain I guess but it would be hard to get it to adjust correctly with let's say a cobra 2000 or something with a 4 watt deadkey, it does real well on my 2950 but I can set it low enough to where it is hardly deadkeys anything, I set the "drive" so the box deadkeys around 200 and let it swing from there and it does real well but if I put a JB12 behind the cobra I can't even get the JB12 to key low enough to where the eagle is happy 1 watt seems to be too much
