KENWOOD TM241 PROBLEM
ve3mud
Jan 8, 2010
Hi - I have a Kenwood TM241 2M xcvr and it appears to have quit working - Symptoms are as follows:
Blank Screen
DIM Light is lit (red)
When press the DR/DT button it gives off 7 tones - 1st 3 are diff (in an ascending order) and the last 4 are the same
No other buttons seem to do anything
Radio does transmit - does change channels - does receive
Checked the input voltage and is fine at 13 VDC
Have tried the resets listed in the manual for the Memory and the VFO but they didn't appear to work - any ideas??
73 es best regards
Ian, VE3MUD
