Kenwood TS-50 display light flicker
n8fis
Nov 4, 2012
3
My TS-50's lighting display acts as if there is a bad ground. No matter what display light brightness you set it at, it will flicker back and forth to full brightness then back to the setting you set it at.
I've looked for this problem a few times now. I even soldered some ground jumpers in hopes to get a better ground to the display.
Anyone else run into this problem? If so, what is the fix?
Besides that the rig is 100% except for it's matching tuner the AT-50 needing reset once in a while.
Thanks for any replys.. Bill N8FIS
bad transistor?
cant remember how those are dimmed.some have a resistor and a tr to bypass and some use a series pass.
