davisrf.com/ham1/dacron.htm
This is a top-of-the line, Double-braided Dacron Rope, black UV inhibited. Won't stretch or break down under sunlight.Use for aerial, verticals, towers,gin poles and telescoping masts.
Dacron Rope
ItemDescription Part No. < 999ft
Price/ft 1000+ft
Price/ft
3/32" diameter Dacron Rope, 260+ lb pull strength. MCL *=3000' DA332 $0.06 $0.055
3/16" diameter Dacron Rope, 770+ lb pull strength. MCL*=500' DA316 $0.11 $0.095
5/16" diameter Dacron Rope, 1770+ lb pull strength. MCL*= 500' DA516 $0.16 $0.145
1/8" diameter Dacron Rope, 420+ lb pull strength. MCL*= 1000' DA18 $0.08 $0.073
7/16"" diameter Dacron Rope, 2150+ lb pull strength. MCL*= 500' DA716 $0.35 $0.320
MCL = Maximum Continuous Length
I use the 5/16" diameter Dacron, it is very strong. You wouldn't need anything stronger for just a ground plane. Also, you can find it cheaper, just do a search for
UV Resistant Dacron Rope
Hossless
</p>
Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=hossless>hossless</A> at: 12/11/04 12:05 am
