Kris 300M
DelR
May 2, 2024
82
85
18
61
This has a 6JU6, which is what the schematic (that I downloaded) shows ot should be. I googled it and it says to be a Beam Power Tube. Sounds good to me. It is definitely antique/vintage and shows about the same wattage as the TX-75 does (on my scrappy meter of course). Seems like I heard one time " about 100w per tube" and "25-30w per pill. Does this sound right?
Reactions: Enterprise312ok
This has a 6JU6,
Plate dissipation for that tube is 17 Watts. For an amplifier with roughly 50 percent efficiency, you'll throw one Watt of heat to the two tubes' plates for every average Watt of RF output.
Round it up to 35 Watts average output from the thing, and with 100% modulation that would be 140 Watt peaks.
More or less what I expect to see from one of those, a 30 Watt (or so) carrier with at least 120 Watt peaks, typically more.
Back in the day, a 23-channel radio with a 3-Watt carrier would get a roughly ten-to-one power gain from one of these.
Assuming, of course, that you can stand the squeal noise from the high-voltage converter.
The way this was explained to me has to do with the high cost of aluminum in Japan. If you can use less of it in your capacitors, your manufacturing cost drops, gives you an advantage over competitors.
Milling aluminum foil ever and ever thinner is what caused aluminum electrolytics to shrink decade by decade since the 60s and 70s. The japanese perfected this as a competitive advantage.
American made caps had no such incentive. Aluminum was cheaper in the USA than elsewhere in the world for a long time.
Sounds right to me, thanks.
