I used to run this stuff back in the 80s and back then they was calling this stuff track wire...back then the wire was a solid copper wire, inside the insulation...I ran about 1500ft of this stuff up a mountain to the top...and had my antenna about 60ft in the top of a tree..
And instead of using what you guys call a Balun, we used RG 213 coax and made a coil, and also a lead of coax, and at the top one end went to the antenna, and had another one at the bottom going into the radio...and we used the coil and lead of coax, took copper gurney clamps, and connected this to the track wire...
And to get the swr down at the radio end, we would slide the coil up and down the line to get the swr zeroed in, close as we could get it....then from here we would add coax or take it away, in which I always ended up adding coax to mine, to get the swr lower.....but once you got the swr down, then you was able to talk on it....
But today everyone calls it Ladder Line wire.....
What does the Balun do, is this away shorter way of getting the swr down, and using the coax with it ?.....
I looked at the pictures of the ladder line and it all looks the same as when we was using years back.....
This all has got me curious about the wire and how the Baluns works and all this stuff..
So take it easy on me guys, Im just trying to learn here....
