Hi everyone! I am new here and have a few things I would appreciate help with. I will only post about one of those in this thread.
I have a circa 60s Lafayette KT320 four-band radio,
which I guess you guys like to call a "boatanchor."
I like that description! It really fits this heavy monster!
The four bands are:
.55 - 1.6 MHz (which I finally realized is the regular AM radio band!!! That explains some of the super loud stations I was getting last night with a local sports game broadcast)!
1.6 - 4.8MHz This one works okay. I was picking up some Spanish stations near the 4.8 end of the band
4.8 - 14.5MHz - No signals
10.5-30MHz - No signals.
I bought this a decade or two ago at a garage sale and played around with it for a while back then. Initially all the bands work as I recall - certainly three of them did, if not all four. I had a "Band-match" 4-way antenna for it back then, but no longer have that. As I recall, on at least one of the bands was VERY tricky to find anything even when it was working.
Now, after years of being stored in a closet, the lower two freq bands are still working, but the upper two bands do not seem to pick up signals.
I only had a 15 or 20 foot wire attached to it for an antenna last night when I tried it out again. Even so, I think SOME kind of signal noises would have come through somewhere on those two higher bands, even if not much.
All I got on those upper two bands was the general background sound that I get on the two lower bands when not tuned to any active signal. But no squeals or clicks or what my father used to call "Diathermy."
There does seem to be SOME kind of changing pitch of the background sound as I goes across the dial, but it almost seems to repeat in a cyclic sort of way slowly as I dial across the band.
To try to narrow down the problem: on these two higher bands, the RF gain makes a difference in volume, as does switching to the SSB position on the selectivity switch. But there is just NOTHING "signal-like" anywhere on those two bands.
I downloaded the manual for this yesterday and looked through it. That gives me the "names" of the tubes and their functions. I will list those at the end of this post because I have questions about some of them.
On the lower two bands I sometimes use the Q-multiplier and set selectivity to SSB position to tune some things in better. But loud signals come in on the "REC-AM" setting and without the selectivity being in "SSW."
There is also an "antenna trim" that I frequently adjust a little as I sweep the bands too.
Okay, I am just trying to show that I have some familiarity with how to fool around with the settings on this old radio to hear things on it. Mostly so that you will make better guesses about the problem with this radio.
I have some understanding of basic radio theory, like general principles of tuning circuits for example, and studied a bit about how a transistor amplifies a signal, and I understand the basics of a simple straight-wire antenna.
But I am not terribly practical nor wonderfully technical in my "hands-on" knowledge. My father taught me how to solder and I built a few small electronic kits in my youth.
I don't know hardly any of the many common abbreviations for things that are so often used by Hams. Please try not to confuse me with abbreviations when helping me. I know that SSB is single side-band and I have a basic notion of what that is - and that the BFO (beat freq oscillator) is needed to tune in SSB voice signals. But that's about the extent of my familiarity with these things. I learned that much from my father when he was still alive and he gave me a Heathkit - maybe SB200 or something. Really not very good but with the BFO I was able to pick up some chatter and plenty of East-Asian nighttime radio signals. I would think this lafayette could do as well or better at getting those, but so far it doesn't seem to get much. Maybe I need to get a little more serious about an antenna wire of the right length for the higher bands.
I know it is pretty hard to tell what is wrong with this radio just from what I am able to describe about what I am hearing, but maybe someone can give me some things to try that would help us to sort out what kind of problem it might be.
Here is the listing of the tubes- from the manual I downloaded:
V1 6BA6 RF amplifier
V2 6BE6 Mixer
V3 6BE6 HF Oscillator
V4 6AV6 Q Mult BFO
V5 6BA6 1st IF Amplifier
V6 6BA6 2nd IF Amplifier
V7 6AV6 Detector, 1st AF Amp, ANL, AVC
V8 6AQ5 Audio Output
V9 5Y3 Rectifier
I don't know what the "Mixer" is.
From what I can tell I think I can rule out problems with the RF amp tube, the Q-mult tube, and the ANL and AVC (since those controls work on the two lower bands), and maybe also the audio output tube is okay; since those lower two bands play voice signals.
I would think that the two IF tubes must be working too - or is the IF different for some bands than for other bands???
But what about the HF ( =? High Freq?) Oscillator tube - could maybe that be the problem, since it is the two higher freq bands that do not seem to be working?
And again, I don't know what the "Mixer" is so I have no clue about that.
Thanks for reading through all this. I hope you can give me some ideas!
The four bands are:
V2 6BE6 Mixer
V4 6AV6 Q Mult BFO
V9 5Y3 Rectifier
