As stated previously, local rules may supersede FCC rules
FCC Citizen Band CFR:
FCC: Wireless Telecommunications Bureau: Rules and Regulations
Operating a Citizens Band (CB) Device
You can operate a CB device in any place where the FCC regulates radio communications. A CB device must be certified by the FCC. A certified CB device has an identifying label placed on it by the manufacturer.
None of the CB channels are assigned for the exclusive use of any system. You must cooperate in the selection and use of the channels in order to make the most efficient use of them and to reduce the possibility of interference. If you operate a CB device, you cannot talk with another station for more than 5 minutes continuously and then you must wait at least one minute before starting another communication.
There are several additional things to consider when using a CB device, including:
You may not raise the power output of a CB device.
You may not attach a "linear," "linear amplifier" or any other type of power amplifier to your CB device.
There are no height restrictions for antennas mounted on vehicles or for hand-held devices.
For structures, the highest point of your antenna must not be more than 20 feet above the highest point of the building or tree on which it is mounted, or 60 feet above the ground.
There are lower height limits if your antenna structure is located within two miles of an airport: If your antenna is more than 20 feet above the ground, the highest point of the antenna must not exceed 1 meter above the airport elevation for every 100 meters of distance from the nearest point of the nearest airport runway.
You may use an on-the-air pseudonym ("handle") of your choosing.
Amateur Radio FCC CFR:
2010 CFR Title 47, Volume 1
Subpart B—Federal Aviation
Administration Notification Criteria
§ 17.7 Antenna structures requiring
notification to the FAA.
A notification to the Federal Aviation
Administration is required, except
as set forth in § 17.14, for any of the following
construction or alteration:
(a)
Any construction or alteration of
more than 60.96 meters (200 feet) in
height above ground level at its site.
